Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Cannot find static symbol
Just trying to use the SDK for the first time, and I want to use this line:
FbxAnimStack* currAnimStack = mFBXScene->GetSrcObject<FbxAnimStack>(0);
But including this line results in the following linker error:
error LNK2001: unresolved external symbol "public: static class fbxsdk::FbxClassId fbxsdk::FbxAnimStack::ClassId" (?ClassId@FbxAnimStack@fbxsdk@@2VFbxClassId@2@A)
How can this be resolved? I have the library linked and I am using many of the other SDK functions fine, I've got the mesh loading and exporting in my own format, I've got the skeletal structure loaded. But now that I want the animation data loaded, I can't get past the above block. That line makes all the difference to whether it looks for this particular static symbol or not.
Best wishes and thanks in advance,
Matt
OK, I resolved it. I wasn't aware that the library with the md suffix, libfbxsdk-md.lib, would be necessary. I wonder now, what MD stands for in this context?
libfbxsdk-md.lib is a static library for Multi-threaded DLL runtime. Try using FBXSDK_SHARED. Be careful, likning statically to fix this SDK issue, means that you are redistributing FBX code, which you are not allowed without Autodesk approval...
