Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Connections with only two constraints
We got a request from a customer that it would be a great improvement if a connector could be defined with only two constraints.
This could be used to rotate an asset around one axis, while the two other axis are fixed.
In this specific case, rotatable fittings should be used.
13 Comments
liqinomickey
Hi @consultingSUKTR ,
Very interesting idea. We also have such idea in our backlog. We were thinking 2 ways of the application.
One way is the safety fencing, the joint would work like 1 freedom in Z axis rotation.
Another one is like piping, the connection will have 1 freedom in X axis rotation.
We would love to hear where these new connectos would you like to put into application? Share with us some user cases or stories, will you?
Thank you,
Mickey
RLenhart
Greate Idea !
lorena.angele
Community Visitor
this is a really good idea and would be very helpful !
This is a great idea!
nikolas.vogl
Community Visitor
Perfect! Exactly what I have needed for a long time
liqinomickey
Hi @RLenhart , @lorena.angele , @Anonymous , @nikolas.vogl , and all other voters,
Thank you so much for the votes. 25 votes in 5 days?! That's a record in FDU Idea Station, as far as I know. But I would like to ask the same question here:
Mickey on behalf of FDU enginieering team
This is a really good idea and would be very helpful !
dominik.raible
Community Visitor
this looks like a pretty interesting idea to me. I think i could have used this function myself at one point or another. Hopefully this will be followed up.
AnJanson
Hi @liqinomickey,
When I wrote this idea, I was logged in with the wrong account, so I did not receive an email, sorry.
In this specific case, it is about the planning of pipes with fittings.
The rotation around the connection direction (X-axis) should be flexible.
But maybe you could realize a solution where the user could define any axis for rotation.
Regards Andreas
liqinomickey
Hi @AnJanson ,
What a star idea!
Piping, got it. May I ask, currently, are you using Inventor Professional? How about the Inventor function Tube and Pipe workflows?
Are you also using Asset Chain function? How would you imagine the asset chaining sketch drawing after we implement this 2-constrain connection?
Mickey
AnJanson
Hi @liqinomickey ,
yes, we are using Inventor Professional. Tube and Pipe is limited in angles and the orientation of segments.
Furthermore tube and pipe is another technology and does not fit in the asset environment.
Regrading the asset chain function, yes, we use it in other customer projects, but mainly for conveyors.
I do not think that the asset chaining would be a good base for a 2-constrain connection as the orientation, especially for pipes, is also vertical.
Andreas
johan.degreef
A replacement for Tube and Piping!
FDU would be great if it could handli Pipes, fittings, falnges, valves in a more efficient way.
Please, go for it šŸ™‚
qamar.naseem6EVRX
This screencast is what my I am aiming for.
https://autode.sk/2S9eMcG.
Eg if I insert this Pin (that could be attached to a door) It inserts correctly due to the way I have defined the RED arrow direction, it inserts in line (0 deg) with the post which is correct, but then once connected, I want to be able to rotate it at angle eg (90deg ,-90 deg), to maybe show an open position. At present if the connector connects it in line and then the reposition tool is used to rotate, it rotates both the post and hinge.
Could we have the flexibility to rotate the asset once connected. ( i would presume Z would be pointing upwards) so that the rotation could be performed
