multiple insertion points
strijkp
Autodesk Autodesk
strijkp
What's the purpose of having the ability to define multiple insertion points on landing plane creation in Factory Assets.
There is no way to select other insertion points on asset placement in the 3D layout.
yizhou.cao
When you place an asset, you should be able to use the Tab key to toggle through the insertion points.
Hope it helps.
Yizhou
Yizhou C
Autodesk Factory Design team
