Inventor not rendering 3D objects from 2D objects in architecture
nbroughton
570件の閲覧回数
2件の返信
メッセージ1/3
nbroughton
I'm new to factory design utilities and I've been trying to set it up for our team to use in our normal workflow.
However, somewhere along the line I did something to prevent the AutoCAD assets from rendering in as solids in Inventor. Let me clarify that this does not happen while placing an object from the asset browser it's only been occurring with items from the Tool Palette. I'm assuming this is a missing file or setting of folder location but I'm not sure where or what to look for.
Using all 2023 products.
I found another forum post from 2016 that someone had just said that the wireframe look is just how it is and that's it's functionality. While using 2021 products I was able to view them entirely as solids in inventor as well. I'm hoping it's just old and doesn't apply. https://forums.autodesk.com/t5/factory-design-utilities-forum/rendering-3d-cad-layouts-imported-to-i...
0 件のいいね
571件の閲覧回数
2件の返信
返信 (2)
メッセージ2/3
hymay1180
Community Visitor
Community Visitor
@Anonymous it would be great if we got a response here. I'm having the same issue.  When I insert walls or roof slab I can see it in 3d solid in architecture but when I render into inventor the walls or roof slab show in wireframe. Please advise.
0 件のいいね
メッセージ3/3
stefanie_you
Thank you @hymay1180 for providing the feedback, as we check the code internally, this is an as-design behavior, would you please help us understand how the wireframe blocks/impacts your workflow? thank you.
Stefanie You
Software QA Engineer
Factory Design team
0 件のいいね
