Factory Design Utilities Not Working with AutoCAD/Inventor 2025
kampsK7UK7
Message 1 of 8
kampsK7UK7
I just recently upgraded my AutoCAD and Inventor to the 2025 versions (from the 2024 versions). I uninstalled all of my 2024 versions of Autodesk products including FDU. After the download, I noticed that the Factory ribbon was not there, so I needed to re-install FDU. When I tried to do this, it gave me an error and said I lacked the host software for this.
Now, if I had to assume, it is because FDU 2024 is not compatible with CAD/Inventor 2025. My question is, do I just go back to the 2024 versions or is there something else I should do? When will a FDU 2025 be released?
Thanks!
Replies (7)
Message 2 of 8
DarrenP
well yea the 2024 factory tools will not work 2025
if you need use them then you need to reinstall the 2024 products
contact Autodesk directly here: https://www.autodesk.com/support/contact-support?startHelpBranch=post-purchase/download-software
DarrenP
Message 3 of 8
kampsK7UK7
Okay, DarrenP. I tried to reinstall the 2024 stuff and it says FATAL ERROR and then crashes whenever I try to open them. Factory Design Utilities 2025 when???
Message 4 of 8
DarrenP
It came out today
DarrenP
Message 5 of 8
neminef862
Observer
Observer
Is there a direct link for it?
Message 6 of 8
Logos_Atum
Hm, somehow this post went online twice- please remove
Dogs aren´t flammable.
Message 7 of 8
Logos_Atum
Hey,
did you check your install using the Autodesk licencing support tool? It´s pretty handy whenever you nee to check the status of you installed products. It´s also great to diagnose your suites status. And you can revoke licences for remainders of installed products, which might help in your case.
In our case, removing of the 2021 version worked only in parts and my collleague had a 2021 FDU listed with an active licence for no reason.
Kind regards
Daniel
Message 8 of 8
Logos_Atum
You can click your signed in user´s picture and choose "products and services". You´ll find any actively licenced product listed there. The links are right there too.
