Connectors Used
Connectors Used
Connectors Used
Hello everyone!
How can I check if a connector actually has some other asset connected to it?
Can I do this via ilogic and change the model with the connector?
Thank you all!
olegd.prod
Hi there,
You can only check this visually. There are no APIs to access/manipulate the connectors.
Thank you,
Oleg
Hi!
No exist an method "is used" for connectors?
Currently I can activate and deactivate connectors via Ilogic, no exists more properties?
If the answers are negative, I can change the component following via parameters?
olegd.prod
Connectors are a Factory construct that is also represented as an Inventor feature. You can suppress features (this is native Inventor functionality), but there is no API access to any Factory-specific aspects of the connectors.
Factory-created instances should not be manipulated through Inventor APIs - this will result in broken Factory workflows.
Oleg
