Connector Class
Connector Class
Connector Class
Hello everybody!
I have created a new class of connectors and this is not fully functional.
Along with this post is the class I created.
The problem is that it is not updating the second asset placed, it is as if there was no trigger for the ilogic rules to update the model.
The parameters of the class exist in the two assets but in addition there are some specific parameters of each asset, however these mapped in the class are common to both models.
When I use this class of connectors in the asset builder it does not show any error, which I understand that with the parameters everything is ok.
Thanks for all.
Ps: I've performed more tests and only the first parameter goes from one asset to another ...
Hi!
This was solved!
A call was made for each required parameter!
<connector _schemaversion_="1.0000">
           <ParedeTipo family_type="normal" value_source="parameter">TIPO_PAREDE</ParedeTipo>
           <ParedeAlturaParede family_type="normal" value_source="parameter">ALTURA_PAREDE</ParedeAlturaParede>
           <ParedeMureta family_type="normal" value_source="parameter">MURETA</ParedeMureta>
           <ParedeLargura family_type="normal" value_source="parameter">LARGURA_PAREDE</ParedeLargura>
           <ParedeAltura family_type="normal" value_source="parameter">ALTURA_BASE</ParedeAltura>
           <ParedeRaioMureta family_type="normal" value_source="parameter">RAIO_MURETA_INFERIOR</ParedeRaioMureta>
           <ParedeLarguraMureta family_type="normal" value_source="parameter">LARGURA_MURETA_SULMAQ</ParedeLarguraMureta>
           <ParedeAlturaMureta family_type="normal" value_source="parameter">ALTURA_MURETA_SULMAQ</ParedeAlturaMureta>
</connector>
