Show tie rods in drawing
It would be nice to see where are the tie rods in CADmep without having to "edit and develop" the item to look at where are the holes.
It work for the external stiffeners, and since the information shows on the developped parts... it's may not be that hard to retrieve and show in CAD?
 We sometimes have to remove tie rods where we install a damper or for any reason, like a tap on the side of the duct. It would also be nice to be able to remove stiffeners "per rod" or "remove rod hole".
4 Comments
aaron.tw
Status changed to: Gathering Support
I am following up to see if it is possible to remove the tod rod holes?
Novybec-YD
Yes. But not with a single tick.
You have to go to the database/Fittings/Stiffeners and edit each stiffener you have there that may have hole for rods and go to BREAKPOINTS.
Then hit the "Show span breakpoints" button and set the "Tie rod hole diameter" to "no cut".
Save and exit.
Then,
I followed the instructions that you outlined in your previous email and the tie rod holes are still being cut out. This is a recent problem that I have encountered, up until a couple of months ago I never had the issue. Any other ideas of how I can remove the tie rod holes?
