Enhanced Multiple Item Properties
I would like to see a button added to the Item Properties dialog box that will quickly get you to the Customize Multiple Item Properties box.
6 Comments
Scott I agree with this. It would make it alot easier with the propeties.
nbaughman
This probably goes without saying... but the "Multiple Item Properties" window is currently linked to the "Edit Database" permission within mapuser.exe. So 99% of our users would not benefit from this.
If implemented, can you please make sure that you remove the permissions required to use this functionality?
cadman_ics
In addition to the permission issue, maybe this should be a user specific setting rather than global.
andy.robins
andy.robins
Status changed to: オートデスク審査落選
andy.robins
