2016 Fabrication Deployments Failing
Has anyone tried to create a 2016 Fabrication deployment? I have attemped to create a deployment for the object enabler, Estmep, and Camduct and they all fail with the same message, "Copy functions cannot be used". At first I thought it was a folder permissions issue but the 2016 Navisworks freedom/Manage deployments were created sucessfully. Attached is a screen shot of the log file and failed setup screen. Does anyone have any suggestions?
4 Comments
I have had the same problem, any suggestions from Autodesk?
None yet. I heard Autodesk is aware and able to recreate the problem.
cadman_ics
I posted a workaround for this to the Fabrication CADmep group on linkedIn a few weeks ago.
Sorry I didn't come here.
Here is the link:
https://www.linkedin.com/grp/post/4684510-5997003278892679172
And here is what I posted:
Autodesk Fabrication Deployment Failure & Workaround
There is a problem with the Fabrication CADmep & ESTmep installers that don't allow a deployment to be successfully created (unconfirmed if CAMduct is affected).
The problem is the deployment creation is trying to copy folders that don't exist (or in some cases I think have already been copied.)
Autodesk is aware of the problem and hopefully will be correcting it soon, but for those that want to create a deployment now, a workaround follows:
1. If you haven't already, download the installer. If it auto-runs, cancel it.
2. Open the downloaded folder, find the file named "Setup.ini" and make a backup, then open the "Setup.ini" file in Notepad (not the backup).
3. Search for the line that starts with "EXTRA_FILES", and replace the line with:
EXTRA_FILES=CADmep;*.exe:*.pit:*.xml:*.mc3:*.mlm:3rdParty:CER:Content:EULA:NLSDL:Setup:SetupRes:Third-Party Component Open Source EULAs
4. Save and close.
5. Run the installer and create your deployment.
It's now been confirmed it happens to CAMduct as well.
aaron.tw
Status changed to: Gathering Support
