- Mute
- Permalink
- Report
We renumber our hangers on a whole floor before spooling and it has worked great for years. Now one of our stations has an issue where spooling an assembly renumbers the hangers for that assembly. Spooling the same assembly on another workstation works fine, preserving the original hanger numbers. The settings in the spool dialog are identical for the two machines. They do use separate local spool.ini files though. Could a setting in that file be the culprit? Thanks in advance for any help you can provide.
Eric
https://www.xtracad.com/forum/index.php/topic,17041.0.html
Eric
