Spooling renumbers hangers - local setting?
efoxSMI
efoxSMI
We renumber our hangers on a whole floor before spooling and it has worked great for years.  Now one of our stations has an issue where spooling an assembly renumbers the hangers for that assembly.  Spooling the same assembly on another workstation works fine, preserving the original hanger numbers.  The settings in the spool dialog are identical for the two machines.  They do use separate local spool.ini files though.  Could a setting in that file be the culprit?  Thanks in advance for any help you can provide.
Eric
https://www.xtracad.com/forum/index.php/topic,17041.0.html
nathan.chapman
The settings you see in your spool dialogue will get written into the spool.ini.  What happens if you give the ini that works to the workstation that doesn't.  Do you get the same result?
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
efoxSMI
Yes I had replaced the spool.ini file with another one that was working properly and the problem went away.  Still figuring out what the problem was in the first place.  Thank you!
