Can you load fabrication cadmep 2018 in autocad 2019? i tried to use appload and got the attached error
Those are version specific. What is your need to run CADmep on a newer version of Autocad?
No need per se but we have the 2019 version of autocad with the newer features. I wasn't sure if you would need fabrication 2019 or if you could just load 2018 fabrication cadmep over 2019. if you do need fabrication cad mep when will the 2019 version of that be released?
Autodesk products are typically released in the next few months.
My last response should of said "Within the next few months all the 2019 products will be out". As you are aware some are already on the market.
