load fabrication cadmep 2018 in autocad 2019
clomedico
clomedico
Can you load fabrication cadmep 2018 in autocad 2019?  i tried to use appload and got the attached error
nathan.chapman
Those are version specific.  What is your need to run CADmep on a newer version of Autocad?
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
clomedico
No need per se but we have the 2019 version of autocad with the newer features.  I wasn't sure if you would need fabrication 2019 or if you could just load 2018 fabrication cadmep over 2019.  if you do need fabrication cad mep when will the 2019 version of that be released?
nathan.chapman
Autodesk products are typically released in the next few months.
Nathan Chapman
nathan.chapman
My last response should of said "Within the next few months all the 2019 products will be out".  As you are aware some are already on the market.
Nathan Chapman
