Add a damper to duct or a fitting in CAMduct 2017
How do you add dampers to fittings & straight ductwork with the quick takeoff feature?
Thank you!
simon_dickinson
 Try editing you SHOP FITTINGS Service.  If you create a new tab called inline fittings, you will then be available to you when you use the quick takeoff tool
