Hi, I'm a high school Robotics teacher who starts the year off with AutoCAD as a lead in to Fusion 360 (and as a necessary skill to operate our Trotec Laser).
Because of covid 19 the AutoCAD Web version was available with education accounts, this appears not to be the case anymore. We used it for students who were away sick(or in isolation) for extended periods of time.
Is this true, and if so, is there a way to have it as an option on those accounts?
Solved by mdavis22569. Go to Solution.
@MDWay, You can still Access AutoCAD Web. It is included with your AutoCAD License.
Go on this Website and tell your Students to Access AutoCAD From here..!!
(https://manage.autodesk.com/products)
Also Direct link to login to AutoCAD Web.
(https://web.autocad.com/login)
Why not have them download and install the full version not just the web. If they are students they should be able to be assigned the software and then download it and use (if they have a capable PC)
However it's included in the AutoCAD Toolset
https://www.autodesk.com.au/products/autocad/overview?term=1-YEAR&tab=subscription
Enjoy a connected design experience with AutoCAD across devices. Create, view, edit and annotate drawings with the AutoCAD mobile app or on any computer using the AutoCAD web app.
Michael, we do have them use the desktop version for the most part. The web app question is mostly for some specific circumstances suck as student illness.
Many of our students run home desktops and laptops that can't handle the system requirements of the desktop version so I have a parallel set of assignments that use the Web app. Also, some schools nearby don't have the luxury of working on Windows desktops and are running programs off of Chromebooks or Chromosomes; for them the Web App is ideal.
Excellent. Thanks. We will try this.
Gotcha ... just wanted to make sure all of the options were out there.
More so since the Web is so limited compared to the full PC version. Just wanted to give all available options.
Just doing a quick follow-up to see if you're all set.
M
M
Yes, these answers are excellent.
