Is it possible to adjust the visibility of Net signals when using the "Show" command in the schematic editor? The old EAGLE v7 used to clearly highlight the selected net signal and I would like to get that usability back. Thanks for the help.
Solved by jorge_garcia. Go to Solution.
Example, this is the old EAGLE behavior:
And the current EAGLE behavior doesn't do this (at least not by default).
