EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Visibility when using Show cmd on a Net signal
2 REPLIES 2
noelQUDAY
461 Views, 2 Replies
Is it possible to adjust the visibility of Net signals when using the "Show" command in the schematic editor? The old EAGLE v7 used to clearly highlight the selected net signal and I would like to get that usability back. Thanks for the help.
2 REPLIES 2
noelQUDAY
in reply to: noelQUDAY
Example, this is the old EAGLE behavior:
And the current EAGLE behavior doesn't do this (at least not by default).
jorge_garcia
Hi @noelQUDAY,
I hope you're doing well. Go to Options > Set and adjust the highlight sliders and play with high contrast mode. I recommend that you highlight something before going to the Set dialog that way you will be able to see the changes real-time.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
