USB Type C super-speed routing doubts
Message 1 of 46
Hi All
I have designed a USB - USB type C receptacle pass-through board. I have started routing the 90R controlled impedance tracks for the USB. I've got the information from the manufacturer to use a trace width of 0.22mm and trace spacing of 0.125mm to achieve 90R impedance. I heard D1_P and D1_N needs to be short to enable the flipping feature. It is a four layer board. I am attaching the schematic and board layout.  Could anyone guide/help me with the layout? Is that correct?
Replies (45)
Message 41 of 46
@Anonymous wrote:
Rod
 Are you sure the facility for checking the diff pairs length is working in V7? I don't see any list underneath.
No sorry I forgot to consider v7 as I have been using v8 and v9 so long now.
Maybe a good reason to upgrade?
Message 42 of 46
Rod
Makes sense now. Probably time to upgrade.
Thanks for all.
Message 43 of 46
This product will probably work better by incorporating a USB re-driver with support for USB 3.1 Gen 1 (5GBps) & Gen 2 (10Gbps) like this one:
https://au.mouser.com/new/Texas-Instruments/ti-tusb1002a-redriver/
https://www.ti.com/product/TUSB1002
https://www.ti.com/product/TUSB1002A
This will alleviate issues with having to use shorter cable length and user confusion when links fail.
FEATURES
  • Supports USB3.2 x1 SuperSpeed (5Gbps) and SuperSpeedPlus (10Gbps)
  • Supports PCI Express Gen3, SATA Express, and SATA Gen3
  • Ultra-Low-Power Architecture
    • Active: < 300mW
    • Disconnect/U2/U3: < 1.9mW
    • Shutdown: < 700µW
  • Adjustable Voltage Output Swing Linear Range up to 1200mVpp
  • No Host/Device Side Requirement
  • 16 Settings for up to 16dB at 10Gbps of Linear Equalization
  • Adjustable DC Equalization Gain
  • Hot-Plug Capable
  • Pin-to-Pin Compatible With LVPE502A and LVPE512 USB 3.0 Redriver
  • Pin-to-Pin Compatible with TUSB1002 Redriver
  • Temperature Range: 0°C to 70°C (Commercial) and –40°C to 85°C (Industrial)
  • ±5kV HBM ESD
  • Available in Single 3.3V Supply
  • Available in 4mmx4mm VQFN
Message 44 of 46
Yes, it's already implemented. Anyway thanks for your advice
Message 45 of 46
Great! Which re-driver did you use?
Message 46 of 46
Sorry, that is done by a contractor as I don't have much information about it.
