EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
@Radius command get error message when routing 'Signal not found'.
1 REPLY 1
dmitri.weintraub
316 Views, 1 Reply
Hello together,
I design very many PCB that are round.
Until Eagle 9.3 I could while I had the route command enabled. Just put in the command line e.g. "@+15".
Then a straight line became an arc.
Unfortunately, this command no longer works properly with the new Eagle versions.
It works only with Net and Line command.
With the Route command I always get an error.
Tags (2)
Labels (2)
1 REPLY 1
Hi @dmitri.weintraub ,
I hope you're doing well. This functionality was dropped from the routing engine some 2 years ago. You can change to a curved trace style by holding ctrl and right clicking to cycle through the various bend styles until you get to the curved styles.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
