Hello together,
I design very many PCB that are round.
Until Eagle 9.3 I could while I had the route command enabled. Just put in the command line e.g. "@+15".
Then a straight line became an arc.
Unfortunately, this command no longer works properly with the new Eagle versions.
It works only with Net and Line command.
With the Route command I always get an error.
Hello together,
Hi @dmitri.weintraub ,
I hope you're doing well. This functionality was dropped from the routing engine some 2 years ago. You can change to a curved trace style by holding ctrl and right clicking to cycle through the various bend styles until you get to the curved styles.
Let me know if there's anything else I can do for you.
Best Regards,
Best Regards,
