EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
problem importing dxf
3 REPLIES 3
neelie2
277 Views, 3 Replies
I am trying to recreate an old pc board of ours that I need Gerbers for our board house.  I have scanned an old mylar plot of the silkscreen layer , saved it as a pdf then made a dxf of it from AutoCad.  When I try to import it into Eagle (which I admit is older - version 6.6) I get this pop-up:
Can't open 'C:\Program Files (x86)\Eagle 6.6.0) import-dxf.scr"
Permission denied
I don't have that .scr anywhere.
3 REPLIES 3
jorge_garcia
in reply to: neelie2
Hello @neelie2,
I hope you're doing well. This error usually means that there was a permissions issue. Where do you have the files stored?
Just as a test try saving the files to the documents folder and then running the import-dxf.ulp.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
neelie2
in reply to: jorge_garcia
Hi Jorge,  Thanks for the prompt response.  I think I have many problems other than that.  I did try as you suggested but with no success.  Is there a way to correspond with you other than through the forum?  I have many other EAGLE related questions specific to my account (which I have to say has gotten extremely confusing since Cadsoft days). I am not even certain which version I can run anymore.
Thank you and if you could just email me directly that would be great!
yqliu
@neelie2 , there is a native insertdxf command and you don't need to use the ulp anymore:
