Polygon rotation
Polygon rotation
Polygon rotation
Good morning. I was wondering if it is possible to arbitrarily rotate a polygon or a wire in my PCB board. I know it's possible to rotate in 90 degrees, but in my project i need it to rotate in different angles, but i couldn't do it like I do with another components, that click-and-drag thing. Could you help me with that?
jorge_garcia
Hi @Anonymous,
I hope you're doing well. You can rotate polygons in any arbitrary angle, with the ROTATE command active you can type whatever angle of rotation you wish to use in the angle combo box and then pressing enter. Once you've entered the angle you want you can form a group containing the polygon and apply the rotation to it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Thank you! I didn't pay attention to that angle box, because I didn't need to use it to rotate the components. Now I may continue my projet in a more efficient way.
