Pin array is missing some features
scott
scott
I've tried for the first time to use the Pin Array feature in the Symbol editor, and there are a couple of limitations which prevent it being usable for my specific need.
- It won't accept a blank Base Name field.  I want to build a connector which just has numbers for pin names, such as 1, 2, 3, etc., but that's impossible with a non-blank Base Name.
- It only has an option to increment by one, so I can't create only odd-numbered pins, for instance.
- I want to create a symbol having odd pins on one side and even on the other, but there's no way to do this.
Scott
edpataky
Great feedback thank you .. it is a new feature so we want to get many inputs from users, this is certainly a useful set of requests .. thank you .. we will discuss internally
