Problem exporting to g-code - help need
Hi!
I made a simple pcb in Eagle 9.2.2 free version.
Yesterday I tried to mill my pcb on my GRBL cnc machine, what actually ended up in a very good and nice pcb.
Quickly I realized I made some mistake and my pins not in correct position.
So, the PinNo1 from my UA741 ic is now on PinNo4 when I rotate may pcb and try to set my ic.
I think I should generate my g-code in some mirror orientation or something like that, but I don't know where and what should I check.
For exporting I use the "pcb-gcode™ Gcode Generation Utility Version 3.6.0.4" which made an excellent result g-code for my cnc machine.
Now I try again to generate my g-code but I always get an empty preview windows when I press the "Accept and make my board" in the pcb-gcode plugin.
I have no DRC errors etc.
Everything seems to me be fine, yesterday it worked, today not working.
Questions:
1. How can I fix my pin number orientation so I can engrave with my cnc a TH pcb?
Should I use the mirror option in pcb-gcode plugin or is there other technique how to make the pcb traces?
2. why have I always empty preview windows after I press the "Accept and generate my g-code" button?
Thak you.
