EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Package Generator failure on building LED
4 REPLIES 4
gwagnerJXG2J
542 Views, 4 Replies
Failure of the package generator on trying to build a Chip LED 3D model.
Throws up 2 error screens, then completes the LED with with a wonky top case.
Attached are the settings I used, and 2 errors that it throws.
BR,
-- Glenn
4 REPLIES 4
jorge_garcia
in reply to: gwagnerJXG2J
Hi @gwagnerJXG2J,
I hope you're doing well. So looking at the numbers you inputted they don't seem reasonable to me. Could you double check the datasheet values again. I get a feeling the errors occur because the LED is not creatable. If you can share the datasheet that would be even better.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
gwagnerJXG2J
in reply to: jorge_garcia
Hi Jorge,
Part is
Vishay VLMY1500-GS08
Clip of the package dimension from the datasheet are attached.
* Glenn
jorge_garcia
Hello @gwagnerJXG2J,
I hope you're doing well. I see what you are running into. I factored in the tolerance and it generates the 3D model but the model top is weird that's probably where the errors are coming from. I'll report this as a defect. In the meantime use the footprint tab to enter in the custom footprint sizes indicated in the datasheet.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
SallyYang
@gwagnerJXG2J , thanks for reporting this issue to us!
I could recreate it with the same settings. And I have a workaround to generate it correcting with the same settings:
  • Generate the LED with the default settings
  • Double click the node in the timeline to edit the package, and input the expected settings to update the package
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
