EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
detected unexpected condition - d_interactiveroute.cpp, Line 669
2 REPLIES 2
gwagnerJXG2J
368 Views, 2 Replies
Fusion Electronics
Was not doing anything fancy.  Tool was set for "walkaround mode" and I just hit "r" to start a manual route.  Clicked on the pad to start the route and received the "Fusion Electronics has detected an unexpected condition."
File:  R:/Electron/EAGLE/src/d_interactiveroute.cpp, Line 669
Had this at least twice today. Similar behaviour.
-- Glenn
2 REPLIES 2
jorge_garcia
in reply to: gwagnerJXG2J
Hi @gwagnerJXG2J,
I hope you're doing well. The fact you ran into it twice is interesting. This type of error is usually a one off. Has it happened when trying to route the same thing? IOW do you have a case that consistently causes this error? If you do we would be super interested in checking the files out.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
gwagnerJXG2J
in reply to: jorge_garcia
Had it a couple more times today. I can't seem to nail down any pattern. I usually close the project and Fusion completely when it happens then restart from my last save (just to make sure I'm not saving anything bad).
If there is anything log wise I can pull or if a dev wants me to run an instrumented load, I'd be happy to help. For now I'll just keep chugging along 🙂
Br,
-- Glenn
