EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
manufacture preview does not display any thing on specific design
3 REPLIES 3
professor_jonny
255 Views, 3 Replies
Hi the manufacture preview does not work for the attached project.
I have tried it with other projects, and it works just not this specific one.
Tags (1)
3 REPLIES 3
Hi @professor_jonny,
The problem with this file is that the outline is doubled on the dimension and milling layers. This effectively cancels out the board outline, which is why the preview doesn't work.
The solution is to remove the milling board outline and just leave the outline on the dimension layer.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
dun_zeko
in reply to: professor_jonny
  1. Check for Double Outlines
  2. Ensure Proper Closure of Contours
This sorted it thanks.
Technology Administrators
