Hi the manufacture preview does not work for the attached project.
I have tried it with other projects, and it works just not this specific one.
Solved by jorge_garcia. Go to Solution.
Hi @professor_jonny,
The problem with this file is that the outline is doubled on the dimension and milling layers. This effectively cancels out the board outline, which is why the preview doesn't work.
The solution is to remove the milling board outline and just leave the outline on the dimension layer.
Let me know if there's anything else I can do for you.
Best Regards,
