EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
library.io thumbnail generation seems to be broken
9 REPLIES 9
Message 1 of 10
lukas.roeder
770 Views, 9 Replies
lukas.roeder
since a cuple of weeks, there are no thumbnails anymore for 3d-packages from libriary.io.
can anybode confirm this?
My Library (since 11.12.2022)
From add-dialog (eagle 9.6.2)
9 REPLIES 9
Message 2 of 10
huib9AQPD
in reply to: lukas.roeder
huib9AQPD
Same here. Did you find a solution? Did anyone of Autodesk replied on this one?
Message 3 of 10
frank.dannull
Observer
Observer
Same situation for me, same questions as user 'huib9AQPD' therefore:
Message 4 of 10
jorge_garcia
jorge_garcia
Hi everyone,
On the 11th library.io had issues but these have since been resolved. Thumbnails do sometimes take some time to be generated but they do generally show up.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Hi everyone,
Best Regards,
Jorge Garcia
Message 5 of 10
huib9AQPD
in reply to: jorge_garcia
huib9AQPD
Hi Jorge,
Thank you for the reply. I am not so much worried about the thumbnail but the 3D object does not sync with my library. The problem is that the 3D object is uploaded correctly and appears in my online library but it does not sync to my library on my computer. When I place the component it does not have a 3D object.
The 3D object also does not appear in my Eagle library.
I made many componets in the past but the last 3 (sins december) gave me problems with the 3D.
Huib
Hi Jorge,
Huib
Message 6 of 10
lukas.roeder
lukas.roeder
More than a month? Really?
This is a screenshot of all public packages on librar.io
and here page 1
and here page 1
Message 7 of 10
frank.dannull
in reply to: huib9AQPD
frank.dannull
Observer
Observer
That' exactly what happens here...
Message 8 of 10
huib9AQPD
huib9AQPD
@frank.dannull @lukas.roeder
There was apperantly an issue with the import of 3D packages.
It should be solved now but no luck on my side. It is still not working.
Any luck for you guys?
Huib
Huib
Message 9 of 10
frank.dannull
frank.dannull
Observer
Observer
Unfortunately not. A lot of rotating gearwheels since December...
Message 10 of 10
lukas.roeder
lukas.roeder
EDIT: i am very sorry, the problem seems to be fixed right now!
C'Mon @jorge_garcia. Multiple users reported the same issue (multiple posts):
thumbnail generation is broken since 11. december 2022.
And it still seems to be a problem.
autodesk cant fix it, because everyone is working on the "fusion-integration" bullshit ??
