Hi Eagle Team,
I'm having trouble adding a library file to Eagle version 9.6.2. Could you please advise on how to proceed?
I've included the following library files for reference:
Any error messages you're encountering are as below
Can you please guide me , How to resolve the Issue?
Thanks for your time and assistance!
Best regards,
Anand Matta
Solved by jorge_garcia. Go to Solution.
Hello @anand.matta,
I hope you're doing well. That happy face is very worrisome. I checked the file itself and it looks good. I think the problem is all of the periods in the file name and in the component name. If it's acceptable I would try renaming the components with underscores or dashes instead of all of the periods.
Let me know if there's anything else I can do for you.
Best Regards,
Yes Sir, Sounds good to me! Is there any chance you could send those working files over again here?
BR's
Anand Matta
Hello @anand.matta,
I hope you're doing well. Here's one of them corrected. To correct the others just follow the procedure I mentioned.
Best Regards,
