How to remove the module sheet from the eagle schematic file?
I also delete the module from the sheet or the part that I'm using in another sheet but after removing it from there I'm not able to remove or delete the module sheet from the schematic sheet list!
Hi @hiteshjangra81,
I hope you're doing well. Make sure that the module is not used in any sheet or any other module. That last one is important, modules can be put within other modules.
Then once everything is clean you can delete them by going into the sheets view and right clicking on the module and selecting remove module.
Let me know if there's anything else I can do for you.
Best Regards,
