How to remove module sheet from the eagle schematic file?
hiteshjangra81
Observer
Observer
hiteshjangra81
Observer
Observer
How to remove the module sheet from the eagle schematic file?
I also delete the module from the sheet or the part that I'm using in another sheet but after removing it from there I'm not able to remove or delete the module sheet from the schematic sheet list!
jorge_garcia
Hi @hiteshjangra81,
I hope you're doing well. Make sure that the module is not used in any sheet or any other module. That last one is important, modules can be put within other modules.
Then once everything is clean you can delete them by going into the sheets view and right clicking on the module and selecting remove module.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
