How to print and export Eagle .sch to .pdf file using student license
How can I print and export a .sch Eagle file to .pdf file.
I am using a student license and cannot find how to do this.
Thanks in advance.
mtl_asm
You can just go to print, then select print to file option under the printer selection menu.
I don't *think* this varies depending on the license, but i am not sure.
Hi mtl.asm,
Again thanks for your reply.
My problem is getting to the print commando (Ctrl+P does not help).
When I go to 'File' there is no print option (Screenshot).
Could you tell me where this option is?
Thankyou.
mtl_asm
oh ok sorry im not that familiar with the version in fusion 360 but i believe if you go to export in that menu you have in the screenshot you may have an option to export as pdf?
sorry i have never used the fusion 360 version, only the stand alone version of eagle, but maybe someone else here can help you.
(the screen shot i posted is from the stand alone version version of eagle)
RichardHammerl
Hi @Anonymous
simply type PRINT in the command line of the editor and Electronics' Print dialog opens.
Richard Hammerl
Hi RichardHammerl,
Thankyou, I should have known this.
