cam processor error "no such file or directory"
I just finished 2 different PCB layouts and was printing gerbers to send to board house.  I generated the first PCB gerbers no issue.  But Now, I am trying to process the second pcb gerbers and I keep getting the same error.
I have tried to restart, I tried "save as" and re generate but I keep getting the same error.  Any ideas?  Thanks
I am using:
Version 7.7.0 for Mac OS X (64 bit)
Premium Edition
Copyright (c) 1988-2016 CadSoft
All rights reserved worldwide
one-of-the-robs
You have an illegal character in your file path. Specifically, one of your directory levels is named "LCR:Pan PCB" and colon is not an allowed character (at least, not without being explicitly escaped). Rename that folder to, say, "LCR-PanPCB" and it should work.
mtl_asm
The problem may be your directory name. I dont know if ":" is valid, or at the least it may be causeing problem.s
Look at your screen cap, teh file is in direcotry
.../Neve Console Upgrades/LCR:Pan PCB/ LCR Pan...
It says it can't find
.../Neve Console Upgrades/LCR/LCR Pan...
This is likely the  issue unless you also have a directory named as above. When is says no such file or dir, it is probably correct, the DIR listed does not exist, but it is incorrect because it cannot parse ":" properly.
edit, what rob said.
I changed the / in the file name to a _ and it worked.  Thank you for your help!
