I want to use an EAGLE standard version to design my product. When I want to pay the license on the EAGLE website, it says I can't buy it and shows this information:
Solved by RichardHammerl. Go to Solution.
Solved by michele.mk. Go to Solution.
Hello @Anonymous,
you can see the answer of your question in you post: you need to contact a Reseller. Did you try to search one for EAGLE in China over the link Authorized Autodesk Reseller? You can also contact Farnell for EAGLE. I hope this is helpful.
I'm sorry to tell you I did search the resellers but none of them sells EAGLE. This is the screen of farnell:
Thanks, @michele.mk. I can buy EAGLE now. I went to the Farnell website and choose US. Then I can buy EAGLE. Thank you for help!
Hi @Anonymous,
I am sorry to hear that at Farnell over the Chinese site you cannot subscribe, it was the information I had so far. I am checking internally with my colleagues about the situation and how we can help in your case.
However, if you are located in China, you cannot buy in the US, since you will need for that a valid billing address in the USA to do so. Could you kindly wait until I have a definitive answer I can give you before you process with a purchase?
I'll contact you back as soon as possible.
@Anonymous Did you get the licence in China, how did you get that? I'd like to purchase a professional version in China as well.
Hi @Anonymous
I think it is not possible to order Fusion (which also gives you access to EAGLE) online from China.
But you could purchase through a vendor. https://www.autodesk.com/partners/locate-a-reseller
I hope this helps.
Best regards,
