@Anonymous wrote:
I am considering upgrading my laptop. My current one overheats when I use Eagle, and it is sometimes painfully slow.
What is the spec of your current laptop? I've run EAGLE on various machines from high spec to relatively low and it's not been a problem. Do you have additional screens attached? If so then you may need a better spec machine with a better graphics processor. I think there is a preference towards NVidia based graphics rather than AMD for EAGLE, I don't know if that is a genuine issue any more, my iMac uses AMD graphics and is fine with EAGLE.
Also, have you got the latest graphics drivers installed and how much other software is running? How much memory is in your laptop, maybe it just needs a memory upgrade?
@Anonymous wrote:
I am wondering if a gaming laptop with a decent GPU would have any positive effect on my use with Eagle?
Is this for business use or is it your personal laptop? For regular use for commercial purposes I would buy a high end laptop that's intended for workstation purposes as they'll likely be designed for rock solid reliability rather than all out performance. I use EAGLE on an iMac and a MacBook Pro and it runs really well on both so that's another option.
I also run EAGLE on a Intel Atom based Gigabyte BRIX which is running Linux. The combination of an OS that doesn't needlessly sap resources and a lower end spec seems to work fine and although I haven't done lots of EAGLE layout work on that machine it's not been noticeably slow so if your current laptop is higher spec than a Gigabyte BRIX then maybe trying running EAGLE under Linux might be an option.
Best Regards,
Rachael
