EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Generic 5 pin relay Library for Eagle
2 REPLIES 2
khaled.azab
17466 Views, 2 Replies
Can someone please help me with the 5 pin generic relay library.
Thank You
Tags (1)
2 REPLIES 2
edwin.robledo
in reply to: khaled.azab
Hi khaled.azab,
Thanks for posting your request on the EAGLE forum.  I attached one I had from a while back, never assume downloaded libraries are correct, I strongly recommend your verify it before actually using it.  Consider using it as a template to make your own.
I hope this helps.
Please 'accept as solution' if my reply resolves your issue.
Best Regards,
Ed
Edwin Robledo
Tech Marketing Manager
in reply to: edwin.robledo
buenas noches, puedes ayudar con la biblioteca para el descanso de 5 clavijas SLA-12VDC-SL-A
