Can someone please help me with the 5 pin generic relay library.
Thank You
Hi khaled.azab,
Thanks for posting your request on the EAGLE forum. I attached one I had from a while back, never assume downloaded libraries are correct, I strongly recommend your verify it before actually using it. Consider using it as a template to make your own.
I hope this helps.
Please 'accept as solution' if my reply resolves your issue.
Best Regards,
Ed
buenas noches, puedes ayudar con la biblioteca para el descanso de 5 clavijas SLA-12VDC-SL-A
