Error:r: Not authenticated. Please try logging in again.
Message 1 of 8
I try to push my Eagle design into Fusion360 but the same error keeps showing: Error:r: Not authenticated. Please try logging in again.
I don't know what is happening and I already tried to log out and logging several times.
Replies (7)
Message 2 of 8
rachaelATWH4
On the occasions I have seen this the solution has always been to log out and back in to EAGLE.
Just to be clear, when you say you tried logging out and in several times, you do mean from EAGLE from the drop down in the top right of the Control Panel view correct? This is not referring to logging out and back in to your system or just closing and re-opening EAGLE.
Best Regards,
Rachael
Message 3 of 8
paul.jefferies.0
I am getting this same error. I have tried logging out in Eagle and back in again (using the menu at the top right of the control panel). I have also tried logging out in Fusion and back in again. Also closing Eagle and re-opening.... Nothing seems to help. I have seen several threads on this where the answer was "sorry, we were updating a server"... maybe it's that again?
Message 4 of 8
I'm experiencing the same error as of a few minutes ago. I hope it's a temporary issue.
Message 5 of 8
reechie
Observer
Observer
I'm having the same issue. Borad pushed to Fusion just fine yesterday. Today, it doesn't work.
Nothing's changed on my end so I have to think it's a server/cloud issue.
Message 6 of 8
Bruce
same problem. eagle has a $hit fit and forgets all prior pushes....
Message 7 of 8
Tbaker25
I'm having this problem too.
Message 8 of 8
reechie
Observer
Observer
Seems to working again. Slow, but working.
R
