The Fusion 360 bar turned red and asked me to pull from Fusion. I complied, but I'm getting an error message. How do I fix this? It would be useful to have some information to work with...
John,
Have you tried using the edit source button in the sync dialog box? I would try using this to relink the board in EAGLE and Fusion and then try pulling again.
If this post helped you please click the answer and like buttons 😄
@johnwYMVVZ wrote:The Fusion 360 bar turned red and asked me to pull from Fusion. I complied
From this I believe you hadn't intentionally changed anything upstream in Fusion360? I've noticed it detect an upstream change I hadn't intended a few times so I ignore it as EAGLE is the master source for the layout. Pushing back to Fusion 360 from EAGLE (sometimes it takes two pushes) usually resolves this.
Best Regards,
Rachael
