EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Error pulling from Fusion
2 REPLIES 2
johnwYMVVZ
347 Views, 2 Replies
The Fusion 360 bar turned red and asked me to pull from Fusion.  I complied, but I'm getting an error message.  How do I fix this?  It would be useful to have some information to work with...
2 REPLIES 2
trey
in reply to: johnwYMVVZ
John,
Have you tried using the edit source button in the sync dialog box?  I would try using this to relink the board in EAGLE and Fusion and then try pulling again.
If this post helped you please click the answer and like buttons 😄
If you found this post helpful, please click the "Accept Solution" button.
Trey German
Founder and Chief Engineer
Polymorphic Labs
Twitter | LinkedIn
rachaelATWH4
From this I believe you hadn't intentionally changed anything upstream in Fusion360? I've noticed it detect an upstream change I hadn't intended a few times so I ignore it as EAGLE is the master source for the layout. Pushing back to Fusion 360 from EAGLE (sometimes it takes two pushes) usually resolves this.
Best Regards,
Rachael
