Eagle - remember settings in grid option
miguelek.pl
Message 1 of 9
miguelek.pl
It's possible to add an option (grid settings) to remember through the program last chosen settings? I don't wanna click to the grid and chose "last". In EU we are using the metric measurement system and I like to work with on-grid. Every time when I open a new project, the settings back to "inch" and no grig visible witch makes me very nervous.
br, Michał
Replies (8)
Message 2 of 9
jorge_garcia
Hi @miguelek.pl,
I hope you're doing the well. You can setup your preferred grid settings in the eagle.scr file that way they stick. In that file under the SCH: heading add a line near the end of that section that reads:
GRID MM ON;
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 9
miguelek.pl
Hi Jorge,
Thx for quick reply.
Eagle.scr I found at: C:\EAGLE 9.5.2\examples\scripts\examples and add row like you wrote. Pls check printscreen. I didn't see any changes 😞
Message 4 of 9
JamesLE32J
Hi @miguelek.pl, what @jorge_garcia has said is correct.
The forum isn't showing images as attachments.  Can you add your screenshot inline in your message, please?  If you can add a screenshot of your eagle.scr too that would help.
Message 5 of 9
one-of-the-robs
That's the wrong file. It's just an example. See this recent post by Jorge
Message 6 of 9
miguelek.pl
Message 7 of 9
JamesLE32J
Take out the line:
Grid default:
and replace it with:
Grid MM ON;
As @one-of-the-robs said the examples file is the wrong file.  The one that is loaded is (if it's a default set up)
Documents/EAGLE/Scripts/eagle.scr
Please edit that one.
Message 8 of 9
miguelek.pl
Once I found the correct location of eagle.scr file, uncomment line "Grid default" and add a new line, save & exit - now is ok.
How to set up my grid size - 50mils? I tried to add a new line "Change Size 0.05in;" but it doesn't work.
Thank you for help.
br, Michał
Message 9 of 9
one-of-the-robs
GRID 0.05 in;
If you want it displayed in metric, you can put
grid 0.05 in;
grid mm on;
