I am having similar problems as mentioned in this topic, but it doesn't stop working, it just never starts. When I start eagle.exe I get the Autodesk Eagle splash screen and then an error message that says eagle.exe has stopped working. As suggested in this thread I tried invoking the program from the bat file and get the same results. I tried eaglecon.exe and a cmd window pops up, the Autodesk splash file pops up and then I get "eaglecon.exe has stopped working". There may be some info in the cmd window, see attached.
I am using Win7 and do not have lavasoft on my computer. I've turned off my antivirus software and still get the same results.
The debug.log file shows an entry like this repeated every time I try starting eagle.exe: [1122/204907:ERROR:gles2_cmd_decoder.cc(12613)] [GroupMarkerNotSet(crbug.com/242999)!:B8A2560A00000000]GL ERROR :GL_INVALID_ENUM : glTexStorage2DEXT: <- error from previous GL command. See attached debug.log file
I initially tried loading eagle into the program files X86 directory and saw in this forum that it should only go into the default c:/EAGLE 8.4.1 directory so I uninstalled everything and reinstalled as recommended (why give to option to change if it is required?).
Fyi, I have another computer running Win8 and it works just fine. I'd just like to be able to work from this Win7 machine because I have it in a more comfortable place in my house.
Thanks for your help.... Please let me know if I can provide any more info to help get this running.
M Porter
