Hi there
I see that you can download a free version of Eagle as part of Autodesk’s Fusion. Also available on the company’s site are legacy versions 6.6.0 to 9.6.0 -- each of which I guess still can be ‘run as freeware’
However, I am specifically looking for version Eagle 6.3.0 – the following:
eagle-lin-6.3.0.run
eagle-mac-6.3.0.zip
eagle-win-6.3.0.exe
Can anyone/Autodesk help/supply these files to me.
I have some ‘legacy board files’ I’d like to amend that were originally developed and produced in 6.3.0 and so need to ensure continuity. I am not an expert in developing PCBs and would need to make sure that the files run properly and there’s nothing untoward going on (which I may not notice) that may occur if I use a later version of the software.
Thanks in advance!
Hi @statkinsonVG8EW,
I hope you're doing well. I would recommend using the V6.6, there were only some minor bug fixes between 6.3 and 6.6 the files will be transmitted faithfully. I don't have V6.3.0 available otherwise I would have given you the link.
Let me know if there's anything else I can do for you.
Best Regards,
Hi Jorge
Thanks for responding to my post about the availability of Eagle 6.3.0. Thanks also for your advice, which is useful and much appreciated. Apologies for my slow responce.
Best wishes
Simon
