DRC- Errors of Width
I ran DRC to check errors, and found many width errors, the majority width errors happened at GND line and polygon lines.
Please see attached pictures.
If someone here has experience on fixing the width errors.
Dawn
jorge_garcia
Hi Dawn,
Thanks for participating in our forums. Width errors occur whenever the widths are less than what is defined in the DRC or a netclass. In this case, it's likely that you have a netclass that is asking for a larger width than what you have used. The solution is to either increase the width of these traces using the INFO command, or to lower your clearances.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
