- Mute
- Permalink
- Report
So, a while back I got a run of boards back and they appear to have a short in them somewhere. 😞 I finally got the time to check the layout files, and I came across this.....
This is clearly an overlap. Two of them, in fact. I'm gonna guess that it happened when a library got updated and those pads got larger. The question is, why did / does DRC not catch this?
I believe the board was made in Eagle 7, but Eagle 8 doesn't see this error either. In fact, the only errors DRC is seeing is some track width and stop mask errors (which are not a problem). Otherwise, DRC says this is fine. This is the first time I've seen DRC miss an overlap like this. I'd really like to know what happened, as I now don't trust the DRC as a valid pre-flight check.
