EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Unable to run EAGLE on Debian GNU/Linux x64
49 REPLIES 49
Message 1 of 50
s.schneider.fr54
2274 Views, 49 Replies
Hi all !
We buy a licence for new version (8.1.0) but i can't start Eagle under Linux : I have this error message on eagle frame:
Please connect to the Internet to
re-authenticate your EAGLE license.
I'm connected to internet, and I don't use any proxy service.
When I refresh window, Eagle write on console the following messages :
qt.network.ssl: QSslSocket: cannot call unresolved function SSLv23_client_method
qt.network.ssl: QSslSocket: cannot call unresolved function SSL_library_init
My linux configuration is :
Debian GNU/Linux 9
Linux 4.9.0-2-amd64 #1 SMP Debian 4.9.13-1 (2017-02-27) x86_64 GNU/Linux
My network connection work finely.
What do i do to validate my eagle authentication ?
Thanks !
49 REPLIES 49
Message 2 of 50
Hi s.schneider.fr54,
Sorry for the inconvenience you are experiencing using EAGLE 8.1.0, I was trying to do some research on Debian v9, but I couldn't locate information on it. On the Debian page we found reference to v8.0 and 8.7, but not Debian/Linux 9.  Consider trying an earlier version of Autodesk EAGLE v8.0.2 for now. We need to take a closer look at this, I have informed the developing team about this thread.
Best Regards,
Ed
Edwin Robledo
Tech Marketing Manager
Message 3 of 50
Hi @s.schneider.fr54,
I hope you're doing well. Try this, in the EAGLE installation folder you'll find a lib folder from that lib folder try removing the libssl library. This will force EAGLE to use your system libssl library. Does that make a difference?
Often when we run into issues with linux it's a matter of removing a few libraries from the lib folder and then EAGLE uses the ones that are on your system.
Please accept as solution if my post fully resolves or you issue, or reply with additional details if the problem persists
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 4 of 50
I have the same issue on Debian. Already tried to delete libssl in the lib directory. I also tried version 8.0.2 but this was not working either.
Message 5 of 50
Hi @inquisitor93
I hope you're doing well. Try removing the following libraries, before you do make sure that your debian install has a version of these libraries already installed.
-rwxr-xr-x 1 apataki users   74192 Feb 22 19:06 libavahi-client.so.3
-rwxr-xr-x 1 apataki users   52792 Feb 22 19:06 libavahi-common.so.3
-rwxr-xr-x 1 apataki users 2049624 Feb 22 19:06 libcrypto.so.10
-rwxr-xr-x 1 apataki users  274208 Feb 22 19:06 libdbus-1.so.3
-rwxr-xr-x 1 apataki users  143920 Feb 22 19:06 libEGL.so.1
-rwxr-xr-x 1 apataki users   13632 Feb 22 19:06 libfreebl3.so
-rwxr-xr-x 1 apataki users  655032 Feb 22 19:06 libfreetype.so.6
-rwxr-xr-x 1 apataki users   51336 Feb 22 19:06 libgbm.so.1
-rwxr-xr-x 1 apataki users  484424 Feb 22 19:06 libgcrypt.so.11
-rwxr-xr-x 1 apataki users  186440 Feb 22 19:06 libglapi.so.0
-rwxr-xr-x 1 apataki users  690392 Feb 22 19:06 libgnutls.so.26
-rwxr-xr-x 1 apataki users   22432 Feb 22 19:06 libgthread-2.0.so.0
-rwxr-xr-x 1 apataki users  348112 Feb 22 19:06 libjasper.so.1
-rwxr-xr-x 1 apataki users  269480 Feb 22 19:06 libjpeg.so.62
-rwxr-xr-x 1 apataki users   22160 Feb 22 19:06 libplc4.so
-rwxr-xr-x 1 apataki users   18016 Feb 22 19:06 libplds4.so
-rwxr-xr-x 1 apataki users  199672 Feb 22 19:06 libsmime3.so
-rwxr-xr-x 1 apataki users  465736 Feb 22 19:06 libssl.so.10
-rwxr-xr-x 1 apataki users   71440 Feb 22 19:06 libtasn1.so.3
-rwxr-xr-x 1 apataki users    5160 Feb 22 19:06 libX11-xcb.so.1
-rwxr-xr-x 1 apataki users   13560 Feb 22 19:06 libXau.so.6
-rwxr-xr-x 1 apataki users   19208 Feb 22 19:06 libxcb-dri2.so.0
-rwxr-xr-x 1 apataki users  115640 Feb 22 19:06 libxcb-glx.so.0
-rwxr-xr-x 1 apataki users   46872 Feb 22 19:06 libxcb-render.so.0
-rwxr-xr-x 1 apataki users   14176 Feb 22 19:06 libxcb-shape.so.0
-rwxr-xr-x 1 apataki users   33152 Feb 22 19:06 libxcb-xfixes.so.0
-rwxr-xr-x 1 apataki users   13760 Feb 22 19:06 libXcomposite.so.1
-rwxr-xr-x 1 apataki users   44040 Feb 22 19:06 libXcursor.so.1
-rwxr-xr-x 1 apataki users   13632 Feb 22 19:06 libXdamage.so.1
-rwxr-xr-x 1 apataki users   81992 Feb 22 19:06 libXext.so.6
-rwxr-xr-x 1 apataki users   22552 Feb 22 19:06 libXfixes.so.3
-rwxr-xr-x 1 apataki users   68496 Feb 22 19:06 libXi.so.6
-rwxr-xr-x 1 apataki users 1425384 Feb 22 19:06 libxml2.so.2
-rwxr-xr-x 1 apataki users   43528 Feb 22 19:06 libXrandr.so.2
-rwxr-xr-x 1 apataki users   43392 Feb 22 19:06 libXrender.so.1
-rwxr-xr-x 1 apataki users  260136 Feb 22 19:06 libxslt.so.1
-rwxr-xr-x 1 apataki users   26584 Feb 22 19:06 libXtst.so.6
-rwxr-xr-x 1 apataki users   22192 Feb 22 19:06 libXxf86vm.so.1
Best Regards,
Jorge Garcia
Message 6 of 50
Hi all,
I tried this 2 solutions and now, i don't have any window. In place, I have a new message :
./eagle: /usr/lib/x86_64-linux-gnu/libcrypto.so.10: version `libcrypto.so.10' not found (required by ./eagle)
I installed all libraries on my system, but nothing works... I would not compromise the integrity of my PC with hazardous installation...
Message 7 of 50
Thanks for your participation. Now we are getting somewhere. The easiest solution would be to reinstall EAGLE remove all the libraries I wrote previous post with the exception of libcrypto and see if EAGLE starts. It seems like that is the only library it couldn't find locally.
The other option is to install libcrypto through apt-get.
Please accept as solution if my post fully resolves or you issue, or reply with additional details if the problem persists.
Best Regards,
Jorge Garcia
Message 8 of 50
Hi
So, I tested this solution, but we have new problems now, like :
./eagle: relocation error: ./eagle: symbol _ZNSt17bad_function_callD1Ev, version Qt_5 not defined in file libQt5Qml.so.5 with link time reference
Mylibrary installation is as follows:
# aptitude show libqt5qml5
Paquet : libqt5qml5
Version : 5.7.1-2+b2
Nouveau: oui
État: installé
It's too complicated to run it. I think that we will use eagle on windows system until the linux version was finalized, otherwise we can not make our electronic cards.
Thanks for your support
Message 9 of 50
I tested all solutions. It seems Eagle 8.1.0 is broken for most Linux distributions.
My platform:
– Intel Core i5-4690 CPU with Intel HD Graphics,
– Gentoo Linux ~amd64
– Linux Kernel 4.9.20
– Qt 5.7.1
– xorg-server-1.19.3
– glibc-2.23
– openssl-1.0.2k
I get just an empty screen.
Message 10 of 50
jorge_garcia2
in reply to: reagentoo
Hi reagentoo,
Thanks for your very detailed system description, our next release will have 4 officially supported distros on which it is tested by our QA team. Gentoo is not one of those 4 however, by Officially testing and supporting EAGLE on Ubuntu, Fedora, CentOS, and OpenSUSE, we will have a version of EAGLE that can run on most Linux Distributions with only minor library adjustments.
Keep an eye out. In the meantime I'm going to report what you are seeing because I recently got a similar result on my Mint box which had EAGLE working just fine prior to an OS update.
Best Regards,
Jorge Garcia
Message 11 of 50
dagPC4JJ
in reply to: jorge_garcia2
I am running Fedora 24 here and I have the problem that I get a screen with: Please connect to the Internet to
Nothing wrong with my internet and no proxy in place.
Running a strace on the eagle startup I can see that it tries to connect to two addresses:
52.206.53.125
and
34.196.34.4
These are both not responding to ping and I presume that eagle then thinks the whole internet is down.
I do so much hate software that needs a connection to the internet to even start %&/¤%"¤&%
Tags (1)
Message 12 of 50
jorge_garcia2
in reply to: dagPC4JJ
Hi dagPC4JJ,
I hope you're doing well. Your issue is different, are you on WIFI? If you try a wired ethernet connection is the behavior the same?
Like I mentioned with this next release users should observe better performance and stability on Fedora since it will be one of the officially supported distros.
Please let me know if switching to wired ethernet makes any difference.
Best Regards,
Jorge Garcia
Message 13 of 50
dagPC4JJ
I am already on a wired net. Anything else I could try?
Message 14 of 50
jorge_garcia2
Hi dagPC4JJ,
Did you try the recomendations in the README that is in the EAGLE installation directory. I didn't see that you did that's why I'm confirming. The solution above of removing certain libraries usually fixes the issue as well.
Please let me know if these don't work for you either.
Best Regards,
Jorge Garcia
Message 15 of 50
New Eagle-8.1.1 is not works.
 ./eagle
Segmentation fault
Please see strace output. https://dpaste.de/ygAD
Message 16 of 50
jorge_garcia2
Hi reagentoo,
This issue is different then the one you reported previously. Have you tried the other suggestions mentioned in this thread and in the README that ships with EAGLE? In general the segfaults are usually cleared by removing some of the libraries that ship with EAGLE.
I would try removing the libssl libraries and having eagle use the ones on your system. Make sure to install libssl if you don't already have it.
Best Regards,
Jorge Garcia
Message 17 of 50
dagPC4JJ
I did try all those. They created more/other problems with missing symbols. Couldn't really find a working combination.
Message 18 of 50
dagPC4JJ
Now downloaded the new 8.1.1 version and tried again on my FC24. Still the same "Please connect to the Internet to
re-authenticate your EAGLE license."
The terminal contains:
% LANG=C ./eagle
./eagle: /usr/opt/eagle-8.1.1/lib/libdbus-1.so.3: no version information available (required by /lib64/libavahi-client.so.3)
Installed Qt WebEngine locales directory not found at location /usr/opt/eagle-8.1.1/translations/qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location /usr/opt/eagle-8.1.1/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
[0419/160806:WARNING:resource_bundle.cc(291)] locale_file_path.empty() for locale
Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory...
Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory...
Installed Qt WebEngine locales directory not found at location /home/eagle/Qt/5.6/gcc_64/translations/qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location /usr/opt/eagle-8.1.1/libexec/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory...
Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory...
My primary ethernet adapter has two IP-addresses. Cuold that be a problem?
Message 19 of 50
jorge_garcia2
Hi dagPC4JJ,
That could totally be it! Is there any way you can force to use only one IP address? Just as a test, I'm sure there is a good reason you have two IP addresses.
Best Regards,
Jorge Garcia
Message 20 of 50
dagPC4JJ
Not possible. It really needs two IP:s as it belongs to one network with access to the outside world and also to an internal network. And being Linux it also serves both networks in different ways.
But no worries. I found version 7.7 of Eagle your old ftp site and this works perfectly fine. I can live with that as it gives me the possibility to convert the designs to kicad with the utilities available.
Seems like version 8 is not for us....
