Hi guys,
I have two questions:
1) I know cross probing highlights individual components on a schematic and PCB, but since I have built my schematic in sections (Power, Control, other subsystems). Is it possible to highlight/probe multiples components on the Schematic and move them on the PCB?
2) I have made 2-layer PCB's before, this time I am trying to make a 4 board. Is there a good tutorial available to get on started with 4 layer boards?
Any advice/help is appreciated. Thanks!
Solved by jorge_garcia. Go to Solution.
Hi Jorge,
Thanks for your info, I will try that ULP and post here if anything comes up.
The application needs additional shielding as well as the current routing is just not possible with a 2 layer board (atleast using the student version of eagle. My PCB max size is limited.) The goal is a to create a wearable, so the board has to be as small as possible.
I will try your suggestions and post back to confirm. Thanks again!
Just wanted to let you know that cross-probing is now a built-in part of Fusion Electronics!
