Hi @ulrich_wetzel,
That's still available it's just not exposed in the UI. Go into the Electronics command line and type EXPORT then press the enter key. You'll get a little menu and you'll see the option Image. Go from there.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
